Renault Car Immobiliser Bypass
fuzzion
Post by fuzzion »
How to bypass a Renault car immobiliser using its bypass de-activation code
For use with cars that have an infra-red key
Någon kan säkert ha nytta av denna site:
http://renaulthelp.110mb.com/
Johan Nilsson
Mégane Coupé 2,0 16v -97
figgesoft
Firstname: Fredrik
Surname: Sjöholm
Post by figgesoft »
nice!
lägger den bland "bra o ha programmen" :)
harka569
Post by harka569 »
Jättebra sida! Någon som "äntligen" tagit tag i och sammanställt informationen på en vettig sida. Jag fick koden gratis från Bilia i Södertälje en gång, men har även fått fram den genom det som beskrivs på sidan.
Men detta:
Re-synching the key fob (may not always work):
With all bypass digits entered, turn off the ignition.
Hold down the central locking button. The immobiliser lights should remain constantly on.
Point your key fob at the IR sensor near the internal rear view mirror and press on/off quickly. Hopefully the key should now be re-synched.
If it is not, wait for the immobiliser light to start flashing and try steps 12-13 again making sure the ignition is off. It may take a few goes or may not work at all in which case you'll have to see your dealer to have it reprogrammed.
...är intressant. Har sett många varianter på detta och hittills inte fått det fungera. Men skall nog testa just detta ovan när min andra nyckel lägger av (läs så fort jag byter batteri... ) :? ... "May not always work"?? Va?? - stabilt system...
Harri Karlsson - Linköping
Renault Megane II Touring 1.9 dCI FAP - 08
