hittade nedan tråd på ett utländskt forum men tyvärr inga svar eller bra lösningar...
Är det nån som har en kvick-fix för mig och min megane? Jag har identiska symtom.
I changed battery on Megane Monaco 2005.
When I put key card into the reader the car will not turn over or start. The Immobiliser light flashes on display panel. Engine cooling fan runs for a few minutes and then cuts out. Wipers work.
I have checked fuses on battery positive terminal and they are OK. I have locked car and opened it again to no effect.
I think it is an immobiliser issue related to key.
Has anyone had a similar experience after changing battery and found a solution. Thanks in advance for any help
Renault Megane 2005 startar inte efter batteribyte
Joacim Åslin
