Spridar programmering kangoo 1,5 dci
Torparn74
Firstname: Thomas
Surname: Puumala
Post by Torparn74 »
Hejsan har en 04:a kangoo 1,5 dci som förra ägaren haft ur spridarna på och han visste inte att dom är positionsbestämda. Så nu släpper den inte fram diesel till spridarna. Min fråga är går dom att nolla och programmera in i systemet igen eller går de att få reda på vart dom ska sitta.
Tack på förhand Thomas.
Thomas P
Torparn74
Firstname: Thomas
Surname: Puumala
Re: Spridar programmering kangoo 1,5 dci
Post by Torparn74 »
Ingen som vet något om detta??
Thomas P
Starbright
Firstname: Johnny
Surname: Søderstrøm
Post by Starbright »
Lite info om denna "kodning"
The importance of IMA injector coding
The IMA coding is an industry standard: Injector Menge Abgleichung (injector Quantity Offset). When an injector goes through the OE test it generates an IMA code which identifies where in the tolerance range the needle and nozzle assembly fit, this allows the ECU to vary the fuelling accordingly and optimise the engine performance. Failure to code in the injectors can result in several issues
• Performance – in some systems it may be possible to drive away and not know any difference. In reality if the injectors have not been coded in it is unlikely that the customer will be getting the optimum performance from the vehicle and may well end up back at the garage with an increase in fuel consumption or black smoke etc.
• Non start – in newer systems if you do not code in the injectors the vehicle will not start
• Poor / lumpy running – as the injectors are not coded in the ecu will carry of fuelling as if the previous injector was still present which can cause poor performance. The engine management is also likely to come on necessitating another visit to the garage.
Vad du måste göra är att koppla in en diagnosdator, ex Clip
Skriva in spradarnas IMA-code för korrekt cylinder.
Gvetvis genom att läsa IMA-coden på spridaren.
Torparn74
Firstname: Thomas
Surname: Puumala
Post by Torparn74 »
Jag har positionsbestämt spridarna och fått fram diesel nu men får nu ny felkod DF166 kamaxelsensor samstämmighet permanent fel. Bytt både kamaxelgivare och vevaxelgivare ande visas samma kod sen får jag även felkod DF 137 bränslerörstryck reglerfunktion ; tryck under minimum permanent fel men hittar ej någon läcka.
Thomas P
john
Firstname: John
Surname: Ignell
Post by john »
Ser inget namn på inläggen 8)
John Ignell Enviken
Torparn74
Firstname: Thomas
Surname: Puumala
Post by Torparn74 »
Ingen med nå tips.
Thomas P
